I'd just get a set of 10mm shims from HotCams. Then you will have all the common needed sizes.Does anyone know what the stock original shim thickness is? I am planning on doing my first lash check and would like to order a few sizes of spare shims. Thanks
Surface grinder, cool. Those bitches are hard. Let us know how far off it was at 47k.Thanks for the advise guys. I will likely order a set. I have a surface grinder so I could likely make do with thicker shims and grind them to size if needed. That's why I was curious as to the stock original size. BTW this is my first v/v lash check and I'm at 47k miles so I'm counting on some needed adjustment.
last time looked at mine I only had on valve shimmed and it was a shim specific to the size needed to get within spec.Does anyone know what the stock original shim thickness is? I am planning on doing my first lash check and would like to order a few sizes of spare shims. Thanks
Hi Tie one ON, thanks for the reply.last time looked at mine I only had on valve shimmed and it was a shim specific to the size needed to get within spec.
Your question prompts one to think if you know how to check tolerances to begin with.
Get a repair manual and read through the process about 5 times or more befaore you begin
by your original question it doesnt sound like you know how to work on the intricates of an engine so It was an attempt at saviving you from yourself.Hi Tie one ON, thanks for the reply.last time looked at mine I only had on valve shimmed and it was a shim specific to the size needed to get within spec.
Yes I have a service manual. You asked if I know how to check the tolerance. We don't actually check the tolerance. We check the clearance(valve lash) between the camshaft and the tappet with the use of a feeler gage. The tolerance is the difference between the minimum and maximum clearance. In this case the tolerance would be .0018" If the clearance or valve lash is not correct, then the shim under the tappet is exchanged for one of the proper thickness to obtain the correct clearance or valve lash.
So are you saying the last time you checked yours, only one of the valves had a shim? I could be wrong but I would think all the valves have a shim between the valve and the tappet. I apologize if I misunderstood your reply.
Thanks, Trevor
Thanks, Trevor
:stilpoke::angeldev:by your original question it doesnt sound like you know how to work on the intricates of an engine so It was an attempt at saviving you from yourself.
so sorry if my assumption was incorrect
PROCEED ON
Here is the "coffee can" method. --> LINK
