I have a 2009 Muscle with Stage 2 cams (installed by HD dealer 4 years and 30K mile ago). When I measured the existing shims they are ALL larger than the biggest from Table D-1 in my service manual. The valve lash measurements were all over the maximum, so the shims need to be bigger. Has anyone experienced this? How do I get shims thicker than those listed in the service manual?
Tie One On
you sure you had the valve train in the correct positions when measured??
Yes, the clearance was measured with the correct engine rotations. It would be impossible to measure a gap if not. My problem is the shim below the tappet is thicker than any listed in table D-1 in my manual. I went to Ronnie’s HD on-line microfiche and found that I can get larger shims. I ordered at my local HD dealer.
