1 - 9 of 9 Posts
Well I guess I'll start with the only real problem my 02 has ever had. Had the rear valve cover sealed three times before they got it right. 6k miles later no more leaks since they sanded the chrome off the bottom and used sealer with the metal gaskets.
Max
spit happens
I am having my rear rocker cover replaced because of bad chrome,I have a feeling that the dealer and I are going to be on a first name basis soon.I don't have much faith in there V-rod mechanic.But the dealer is 40miles away.and I don't know how good there mechanics are.
My friggen LEAK is back!:mad: After my day on the dyno It started up again!It splashes on the rear tire so it must be fixed by the weekend or I'm screwed.........:(
Kaz, what is leaking?
vilzrod, with 400 miles is your bike not under warranty still?
I will assume that you are currently running the 220KMH speedo. No I have not seen it done yet but my checking of the data of the speedo says that it should be a plug and play exchange. I have tried both a 220 KMH and a 140mph on my 02 and they both use a 4,000 pulse per mile signal and the switch is a simple plug and play. So my guess would be that the new 150MPH and the 240KPH still use the same signal and just have a different pulse width generator on the motor.
Max
spit happens
I was right.leaking from the back left side of the rear rocker.Now I can't wait for the water pump to leak.They never fixed the coolant leak(overfill tank) from the last 2 times they tried to fix it, that started again:mad: and it's worse.I guess I'm gonna have to make an appointment for both leaks.That bites because it's going back to the dyno friday morning.Gonna get some more torque hopefully.:D
1 - 9 of 9 Posts
