1 - 10 of 10 Posts
Fah q 2
With an older bike (no O2 sensors), is it possible to use wide-band O2 sensors for the v-tune program?
Ex-sunshine rider
I am pretty sure you can't as the ECM is different and you cannot load a MT7 file on the older ECM if you look in the mastertune section you will see a reply from Steve Cole on a similar subject.
Maybe someone else will second this.
Fah q 2
i read some where that all i have to do is get the stock o2 sensors and install an updated map into the ecm.
i also read that they have instructions for doing this in their help files.
can anyone with this unit confirm this?
everything I have read suggest the ECMs (hardware) are the same through the years. The program(s) would be the only difference. I know this to be true of '06 through '11, but have not had the opportunity to test pre '06 ECMs
Ex-sunshine rider
ECM Part numbers
Checked my library and MJW posted the below a while back..
There are multiple versions of the ECM.
32852-08
32852-07
32534-05
32534-05B
32534-05C
32498-05
32498-05A
32784-01
It looks like 4 different hardware and 8 different firmware versions. These are listed newest to oldest. The -01 is for the pre-'05 bikes and is no longer available for purchase.
32852-08
32852-07
32534-05
32534-05B
32534-05C
32498-05
32498-05A
32784-01
So wouldn't that mean or suggest that all the newer ECMs would be backwards compatible and just need a firmware/reprogramming to work?
Fah q 2
thats what i was led to understand, that with my 2007, i would use the narrow band o2 sensors with the ECM i already have
In digging through the ECM from my '07, I know it to be capable of handling and utilizing the input from wide band O2 sensors IF it had the correct programming.
Fah q 2
from what i understand, it can already handle the NARROW o2 sensors, the wide band sensors wont work
Fah q 2
are their any beta testers that can confirm this?
in the manual it states that BIG TWINS can be retrofitted,
so I am assuming that the Revolution's ECM is excluded
TTS has no support on there site so my only hope is in forums
that really sucks on their part
1 - 10 of 10 Posts
