Try Brian at Hogbitzspeedshop in Chigwell on 0208500 9025, or Andy Harris AHCC in Maldon, Essex 01621 841114, both deal with left handers, check both websites.
you might want to post what map you have and see if someone here can tweak it for you, or look through the efi section and see if someone is running the same setup as you that has posted their map.
why cant you fit the pc3 yourself (it is pretty straight forward) and select a map from the forum, then perhaps tweak it yourself and finally dyno it when you feel it has a map near what you want ?
