I found this and thought it was pretty cool
http://www.cyrilhuzeblog.com/2010/05/20/harley-davidson-v-rod-revisited/
All I can say is...Yes please Santa:moped:I found this and thought it was pretty cool
Yeah, but I don't think SculptureCycles frame will handle worth a darn. That's just pretty boy crap.That's a pretty wicked frame!! I would look into buying one. I know SculptureCycles has one right now for about 6k
:them: Yeah, you could do that now just by removing the lower frame rails on both sides. While I like the look of the frame, I don't think the Revo has the correct mounts to be a stressed member. Therefore, I suspect you'd get a lot of flex or rocking. Also, where are you going to hang the water and oil coolers? You'd need something new to go with the cool looking frame.Yeah, but I don't think SculptureCycles frame will handle worth a darn. That's just pretty boy crap.
Oil and water coolers are not problems to locate. Roehr uses the V-Rod engine as a stressed member of a twin boom aluminum alloy frame, so your other objection may not be a problem at all. Here is an article on the Roehr bike that shows the engine and frame without bodywork or radiators. Looks like the stressed member part has already been done with success.:them: Yeah, you could do that now just by removing the lower frame rails on both sides. While I like the look of the frame, I don't think the Revo has the correct mounts to be a stressed member. Therefore, I suspect you'd get a lot of flex or rocking. Also, where are you going to hang the water and oil coolers? You'd need something new to go with the cool looking frame.
