During rush hour no less! Started surging a little on the way home yesterday and did it a little worst this morning. Read up on the fuel flange fitting issue and thought that might be what it was – and would check for the mist in the fuel tank when I got home. Well it wasn’t to be. The bike was running like absolute S**t – surging and backfiring and finally about four miles from home started to die and then oil came out from somewhere in the front on the engine. I hit the kill switch, pulled the clutch in and coasted up a convenient exit ramp and down into a shopping center.
What is going on?:wazzup: Can the fuel flange fitting issue deteriorate so quickly into a major shut down? The bike didn’t set any engine codes and would crank up – but sounded pretty rough. The oil checks full and is clean. I still can’t see any obvious area where it may have come from. It seems to have come from the top end of the front cylinder. No more is coming out.
If anyone has had something similar happen could use some help.
