1 - 3 of 3 Posts
I installed a security system vrsca 2003 68 200-00D. After binding FOB Key tried to start the engine. The engine roared into life for a second and immediately shut down. In what may be the reason?
Old TSSM engine starts normally.
The 68200-00D TSSM requires more than just a FOB setup. Do you have the Electrical Diagnostic Manual?
This module needs to have the password set. I attached the instructions from the 2002 EDM page 3-61 Table 3-27.
As you can see, this will require more than 30 minutes of ignition “on time” without the engine running so make sure your battery is good and pull the LIGHTS fuse before you start.
1 - 3 of 3 Posts
