:them:coinpurse said::worthless
Yes thats the outer baffel... I would recommend using a dremmel with the sanding tip to round or oval out the holes to the same size and shape you want..BJKELLEY said:Thanks for the reply. One of mine got a little bigger than I would have liked and just wondered if I should make the other one match it in size. You mentioned the outer baffle, the only thing I see on the inside is a meshing around the inside of the pipe. is that what you are calling the outer bafle? because it isn't even close to that.
thanks again for the reply
