1 - 1 of 1 Posts
All,
I have the 2nd version of the V&H Destroyer pipe on my Special. It sits so low that I have dragged it to the point where I have ripped the bottom spring support off of the pipe as well as the screw that holds in the baffle, leaving me no where to secure a baffle.
I'm looking at replacing with the V&H Destroyer pipe used that's made for the Muscle. My friend has the Muscle with this pipe and the spring is located in a better place as well it has more clearance then the new Destroyer pipe for the Special.
Questions:
1. Has anyone used the Muscle V&H Destroyer pipe on the Special?
2. If so was there any problem with the fit?
3. Were you able to use the Map that was used for the Speical or did you use the Map for the Muscle?
Thanks,
Worm
1 - 1 of 1 Posts
