1 - 7 of 7 Posts
So, my buddy and I installed the Vance and Hines comp series pipe yesterday. The exhaust flange is tight but it does not touch the head, there is about 1/4" or less gap between the two. Is this normal? Seems like it should touch the head all the way around it when tight.
2013 NRS
V&H Comp Series 2 into 1
New Exhaust gaskets # 64971-09
New clips
Discussion Starter #2
This is making me think the header is not fully seated into the head. Also, as you know the oe exhaust is tapered/rounded at the end and the gaskets are the same. The V&H keeps the same profile all the way to the end (no taper). Seems like V&H should make their header taper to match the gasket.
also only got the nut on to the point that the stud is flush with the top of the nut. felt tight and didn't want to damage the stud so I stopped there.
Since there has been no replies, I'll assume I'm the first to install this exhaust system and all others can learn from my experience/mistakes or triumphs..LOL
hey go fast06 here ,put the same V & H style pipe on my 06 V-Rod . I thought the same thing when I mounted mine up but it seats like that . Just don't overtighten those flange nuts! check em every so often. Love the sound !
Air Ride Help
Ride a 06 V-Rod with a 240 kit in back but next on my list of goodies is a air ride system anybody have any recommendations or experiences with the air ride kits out there ? Any help is greatly appreciated !
1 - 7 of 7 Posts
