hi folks I just put my new exhaust on my 2012 nrs eventually got them in the ports but then noticed the rear exhaust was about a inch longer than the front now I don't j now why but seems either they were cut wrong or bent wrong. eventually got the silencer on but then the bracket wouldn't reach the frame mount. any one else had this and what did you do to sort it. or am I doing something wrong ?
many thanks
john
hi all. for any one fitting the v&h 2-1 the only way they will fit and line up is if you cut the gaskets right down so you basically only have the washer part left. I found out from Harley that's how you fit it. def on the 1250s 1130s might be different hope this helps any one fitting 1.
John
