when opening an downloded file a pop-up appears;unsupported file type hd-v159 my sert version is 4.5.3,so it should be able to open .mt6 files. anyone had this before?
I'll have to look on my laptop but I thought 4.5.3 was designed to work with mt5 files.
the files that came with the sert are all mt6. davetpilot was so kind to post his map for the caliber exhaust in the vrscr section 06 VRSCR, SEAC, CALIBER DUALS, .MT6 (46.3 KB, 5 views) but somehow tuningmode cannot open it
SNAFU
If that is the file name, with all those commas ans spaces then it's likely the software can't interpret it. Change the file name to something simple like "map2.mt6" and see what happens.
tried it,no cure the message is ; unsupported file type detected this file was developed for a different tuning mode application and is not compatible with this software the file type is hd-v159 :banghead:
the problem appears to be the sert versions i am using version 4.5.3 while davetpilot has the 4.6.0 version. are using mt6 files so one expects compatibility from other threads i learned the the newer version should be compatiable with vista but i'm running my 4.5.3 version under vista work fine. :confused:
