A lot of the "Busa Boys at the track use a two step box to get their launch rpm consistent. Has anyone experimented with a two step for the V-Rod? I've looked around and no manufactures I've found make one.
For those new to drag racing a two step stutters the ignition to hold the rpm at a pre-set limit and is usually controlled by a clutch switch. Clutch in, you're at launch rpm, clutch out and you're at WOT. You can tell somebody's running one because the bike makes a popping sound when the two step is working.
Scott
opcorn
Scott
