Two gas lines
1 reading
515 views 1 reply 2 participants last post by  ElrodontheV-Rod
#1 ·
There are two gas lines running from the gas tank to the engine. One is the supply and one is the return. They have different part numbers so how do you tell them apart? I removed mine not understanding I would need to put them back in the correct order. The only thing I can see difference wise is one appears to have a slightly smaller diameter BUT WHICH IS WHICH?
How can I identify the supply from the return line?
