Same weight as stock, pick your favorite brand...Amsoil, Syn3, Mobil 1. I've used all 3. If you use ANY brand, make sure it is compatible for a motorcycle with a wet clutch.
What is more important, is to let the bike idle for a few seconds after a hard ride to cool off the bearings in the turbo and prevent the oil from coking.
bad to the bone
Discussion Starter · #4 · (Edited)
Iat
What did you turbo guy's do with your IAT sensor?? Going chain and sprockets running stock wheel on back with 260 tire do you run a dished sprocket?? if so what offset?
