1 - 3 of 3 Posts
bad to the bone
Where did you guys with Turbo but the IAT?? and for chain and sprockets did you go with the off set ?? I'm running BST carbon fiber and a 260 on the rear.
If you have a turbo, I would suggest you put the IAT in the plenum above the throttle body. You are telling the motor the air temp before it goes into the cylinder, the plenum holds that air after its been heated by the compressor, charge pipe, etc. Keep the belt if you can.
1 - 3 of 3 Posts
