Two 2003 VRSCA's: CTHULHU is Black/Sterling, N/A ; EVIL TWIN is Anodized and S/C
Update from TTS-Performance: 98% ready to ship. Waiting on a bracket to be anodized.
I would get wrenching asap as the amount of dyno time you need will be more than you expect. Between the cams and the blower I would estimate a good 2 days of dyno/tuning time. You will have to dial in your VE table which will take a decent amount of time regardless of what spreadsheet/tool you use to create a baseline map.Knut J I sent an email with an invoice request to MecTec for the caged bearings. On your recommendation! Let's hope Kjell-Anders Sildeman can work with me as he hasta ship from Sweden to USA. I have time, am in no hurry as you can see on my build sheet above. I shall begin the tear-down in August when my buddy visits from North Dakota. He's going to help me film, photograph, and catalog it all. Then I'll have approximately 3 months to build it before my Dyno appointment. Should be enough time to wait on parts and account for anything I might have overlooked.
Bold statement (i.e. C16 and no knock). It certainly will give you a ton more latitude in timing advance, but to what amount at what load I couldn't say.Yes SRR you are correct. I would still like to go the PCV route but Dan told me if I consistently run C16 fuel and it is tuned to a T that there should be no knock. I'm nervous about this but he discussed it at length. He is a vendor for both systems. He's not biased one way or the other because I'm going to buy either one of them through him anyway. I'm not sure I completely understood him. But there is time for additional conversations before we decide.
Ron here. We decided against usning the PTI part, which all the PCV are capable of, just so you know. Only difference is if you order the PTI it comes internally wired, which is only one wire you would add to the sockets of the PCV box anyway to read the 2 or whatever bar MAP sensor if it's installed. We went with TPS tune instead, mostly due to the pulsey nature of the v twin a lower rpms, not real friendly in that area for stable pressure readings. In Johns case, it's PCV with Autotune set up for TPS tuning.Bold statement (i.e. C16 and no knock). It certainly will give you a ton more latitude in timing advance, but to what amount at what load I couldn't say.
Another thought....is this a drag bike only? You know why I ask (VP C16 is about $25.00 a gallon right now!).
As for "best of both worlds" when it comes to aftermarket ECU and boost capable? I'd talk to Ron and JohnR about the PCV PTI (I think that's the correct acronym). It's a "piggyback" unit, but it retains the Delphi ECU + allows the PCV to intercept signals and let you tune based on MAP sensor values and/or TPS all boost referenced.
Not trying to be "that guy", but the DTT is kind of like carving with a butter knife (and their support is a joke).
Ah! I vaguely recall that detail from you guys. So essentially you are tuning alpha-n style.Ron here. We decided against usning the PTI part, which all the PCV are capable of, just so you know. Only difference is if you order the PTI it comes internally wired, which is only one wire you would add to the sockets of the PCV box anyway to read the 2 or whatever bar MAP sensor if it's installed. We went with TPS tune instead, mostly due to the pulsey nature of the v twin a lower rpms, not real friendly in that area for stable pressure readings. In Johns case, it's PCV with Autotune set up for TPS tuning.
Yup, Alpha-N. Big difference or choice for using PCV was boiled down to keeping ion sensing function intact. DTT or TMAX do not use this feature, which we both thought being it's road tune, on a base cal we made up, a feature worth keeping . We can log the bike with PV and look for any knock events that way. Started with POD logging but it's limited in file size per run(s) . So far, I've only seen on minor -2 pull from a knock event, which went away with more refinement from the autotune process. I will say this and sure John will agree, road tuning a SC is an absolute prick to do. Not enough time spent in an area of higher tps areas for quick data collection. It accelerates too fast. 🤣 Dyno rules in that regard.Ah! I vaguely recall that detail from you guys. So essentially you are tuning alpha-n style.
Hi mate, i'll be happy to follow this post!Updated Build sheet. I have both the DTT and the PCV on here just to bookmark the part numbers. Have to choose one over the other. My Dyno guru is now Dan Thayer. He uses both but is leaning towards the DTT for my build. He specified C16 fuel for it and wants to run it in late November/Early December. So now I have a completion deadline. I can always rob the V&H Comp. Series 2-1 I have on Cthulhu for this build if money gets tight. I can also pull the dyno run with the belt drive and switch to chain in the spring of 2023 if money is tight. Main thing is getting it there on time for Dan. He wants it cool out but not COLD because his dyno booth is not heated and he runs several fans. He dresses for the occasion but doesn't want to have to wear a fvcking snomobile suit lol! He gets too busy any other time of the year so this is my DEADLINE!
