1 - 3 of 3 Posts
Hey I'm trying to install my original mufflers after having the v&h widows. I attached the top bracket and the bottom one but the 2 screws that are supposed to attach both slip on mufflers are not lining up. Is there a adjustment somewhere? Can anyone hep me out with more info?
Thanks
Sent from my SM-G955W using Tapatalk
The Massive Pr1ck
One thing about the fitup of higher quality OE exhaust is that it can be a pain due to closer tolerances in the joints making it critical that all is lined up perfectly. Loosen everything to the heads and just spend some time moving it here and there. Go have a beer and repeat until it falls together. Even on my hand built exhaust this happens. Seems impossible to line it all up then it magically falls together when I've had just the right amount of beer.
I agree with Mike....beer helps but you have to find the right amount. Too much and you'll call it a day.
Loosen up ALL the bolts connecting the exhaust system. When everything lines up start seating the bolts until all are "finger tight".
When all the bolts are torqued to spec...have a few more beers......
1011555, I guess the Noise Nazies in QC are clamping down!
1 - 3 of 3 Posts
