What are you guys that have put a boost gauge on you CP kit seeing for max boost?
I have an adjustable wastegate actuator on mine. It was not preset correctly unless 5.5lbs boost is correct.
I adjusted it up to 7.5 lbs and my 7000k rpm stumble/stutter is now gone. It accelerates hard to 7.5psi, maybe a c hair more and flutters until I shift then the boost drops and builds up again.
I own an airport and just made a few 3 gear passes down the runway. It runs much better and pulled the front end shifting to 2nd.
Now to figure what is the safe level to run it with the CP provided map.
cruizer
cruizer
