1 - 2 of 2 Posts
Cyclevision has a kit to allow the use of the HD quick disconnect mounts. The total cost of the two parts is about the cost of the tour pack. There is some question as to whether it interferes with the HD saddlebag mounts, and I'm not sure about the fit. I just bolted my Tour pack to the luggage rack. When I added the 3 gallon tourtank I had to reinforce the combination.
There is a thread about a steel extended luggage rack, and I recommend this for a tourpack installation if directly mounted. If you mount the tourpack about 4" back, then you can access all four rack bolts and the whole thing can be removed in a couple of minutes.
1 - 2 of 2 Posts
