1 - 20 of 47 Posts
Decided to go topless today, after checking that all was well following the repair.
Took off the air box top and relocated the sensor with a spring clip to the side of the base. Took it for a drive the long way home. Interesting new noises, possibly a little more snap (but who can say for sure). Definately no downside. I am running the stock 16ga SE pipes, the K&N air cleaner, and the factory ECM download for that combination. I'll report on any unusual effects as I see them, but so far it seems to run just as before (ie: perfect).
Curious to know if others have similar experiences. Every thread I have come across has several things changed at the same time, so I'm curious to see what changing just one thing does. In theory, it shouldn't change anything - just the opposite of a slightly dirty air cleaner, and even the open loop FI system should compensate.
Comments???
spit happens
I took mine off before I added my supertrapp v-5 system,pcIIIr,and k&nfilter.I noticed a little more response and low ens torque.I didn't think I hurt it any be being lean,Heck the motor loved it.
I have a new cover sitting right next to me . I have the identical set up that you have. I have been "pondering" a couple things for about 2 months. I think I will take a roto-zip and cut a straight line 6 inches across about 3.5 inches back from the "snorkel". Then make that straight cut into a 2 inch "flap" that will look sorta like this [______] . Then heat up this and bend it up so it is above the rest of the unit by about 1/2-3/4 of an inch. It still has to fit under the Aluminum Lid .That way it will allow more air at idle , and be like a scoop while moving. I am also contemplating cutting the snorkel at about a 45 degree angle to both shorten it a bit and allow more flow via a larger area to scavenge from. It will allow the proper/stock fitment of the sensor and keep it protected / yet allow about 30-40% more open space for air to get through.
I am also hoping that it keeps the majority of rain out as I am not a fair weather rider. As long as it is not nasty rain, or real cold , I still ride to work. It just makes me wear a helmet if it is too cold.
This is just a rookie doing a test. :slap2:
BobT
Choppersteve at V-Mod has tried a bunch of combinations, all to no avail (he has reported). I think either Kaz or Ketsuego has tried the swiss cheese approach. Topless seems to be the most benign approach. But go for it and let us know...
It looks like the only way to get a ram effect to work would be to get more air through the aluminum cove; perhaps some of the fiberglass replacements could have some sort of scoop molded in to feed air directly to the airbox.
I like the intake noise at full throttle. The valve noise at low rpm is bothersome. So what did you do? Lop off the front?
Well Frank, I told you it was crude, but it seems to work. I know I have lost nothing. On Sunday, one of the other V-Rodders riding with me has had his bike dynoed at 115.6 rwhp. He also has the 28T pulley. We dragged 3 or 4 times and every time I blew his doors off. We went from a standing start and from a 20 mph roll on. I would get him by at least 3 bikes every time (to 120 mph or so).
I took off about 2 inches off the snout and smoothed the edges first and then cut the ugly holes.
John
If You Ain't Cav...
:rofl3: :rolleyes: :notworthy
I am a little deaf from being inside the turret of all those tanks early on in my officership, so I don't mind the noise so much of removing the entire thing.... But Maryland has a long cold/wet winter ahead... and the rotary tool may be calling........
Mike:cool:
Greg/Moderator
John .......I'm running the pcr3, home made v-mods -020 map, KN filter and top less. So if I trim the top air box this mod will increase HP, torque? By looking at it I think that it would help direct the air flow better than running topless.
1 - 20 of 47 Posts
