1 - 3 of 3 Posts
hi, I`m changing my air box cover on my 2007 NRS, in doing this I`m fitting the clocks into the cover which means replacing the risers, the risers I`ve ordered are unthreaded, so I have use a bolt down through them, the hole in the risers will fit a 19mm head, I`m wondering what the size holes are in the triple trees for the bolts to go down through ? thank you
Holes in the tree are 10mm. You need to drill them out to 1/2" to use std risers.
1 - 3 of 3 Posts
