1 - 11 of 11 Posts
Scott
Supplies:
____ 5 qts. of Amsoil 20W-50 - www.modernoils.com or contact Ken - o2man98 or similar brand
____ 1 Amsoil Chrome Oil Filter, K&N Chrome Oil Filter or Black H-D Oil Filter
____ 2 NGK Spark Plugs - Part #4179 DCPR8E or others (BUT NOT SPLITFIRE)
Software:
____ Service Manual - H-D Part #99501-___ <-Your bike's year here
____ Anti-Seize for Spark Plug lubercation
____ Duct-tape to cover air intake holes
____ White Permatex (or similar) Thread Sealer for Oil Plug installation, if desired but not necessary
____ 6+ quart oil pan (very low profile if you don't have a bike lift)
____ Funnel with extension tube or similar device
____ Packet of Shop Towels
____ Container of Latex, or similar, Gloves
Hardware:
____ Bike Lift WITH STRAP DOWNS!!!
____ Magnetic Tray to hold & organize fasteners in one place
Oil Change:
____ Smaller Torque Wrench able to torque to 25.8 FT/LBS
____ 17mm Socket for Oil Plug Removal
____ Filter wrench or small Strap wrench for oil filter removal
____ 1/2" Socket for Radiator Support Bolts if you need more room to remove oil filter
Spark Plug Change:
____ 5/8" Spark Plug Socket with 6" extension
____ 6mm Hex bit with extension or longer allen wrench to remove coil connectors & intake stacks
____ 10mm Socket for Battery Cable Bolts - DISCONNECT NEGATIVE FIRST!
Miscellaneous:
____ H-D Coolant to refill if needed
____ DOT 4 Brake Fluid for Brembo Brakes, DOT 5 Fluid for all others - refill if needed - Need Phillips Screwdriver
____ Airbox Gasket if torn
____ Tire Gauge
____ Beer :cheers:
Pan American Son of VROD :-)
Forgot to include BIG HAMMER. :)
Great list, just done my 10K using Syn3 which works fine and NGK DCPR9E Iridium Plugs. Feels much sharper!
Re the plugs I have read the posts re the Knock sensor etc but I am not convinced that the change in a standard motor is too significant. I am monitoring performance just in case;)
If you have a stroked, BB or charger then significant re mapping is required so this needs to be taken into account.
Friend of Max.
Critiques, not Criticism
Amsoil has no "e."
There are no carbs on these bikes.
The bikes without Brembo brakes use silicone based brake fluid. The Brembo brakes use DOT 4.
Off the top of my head, there is no need to put thread sealer on the oil plug.
Scott
myneed4speed said:
NGK plugs??? Isn't there a concern about fine wire plugs? Great list that is the only question I have.
It's my understanding talking with Ken from Amsoil that the part # above is NOT the fine wire version of the NGK plug.
Scott
Updates and corrections made...thanks guys!
Friend of Max.
Line 2:
Amsoil still has an 'e.'
I'll shut up now. Nice work. :cheers:
Friend of Max.
VrodG said:
Not on my bike....:)
Some people just can't follow directions. :laugh:
Scott
Discussion Starter · #11 ·
OCD addressed!! :)
1 - 11 of 11 Posts
