The front end will be stiffer, but that's about it.
The VRSC manuals have indicated fork oil level values that many say (including after market companies like Race Tech and Progressive) is way too much. E.g. the '02, '03 and '05 VRSC Service Manuals list the fill level as 3.3" (84 mm) from the top. The preferred value is 5.1" to 5.5" (130 mm to 140 mm) from the top, almost 2" (46 mm) less oil.thats fine ,,,lol,,one more ounce going in ,,,i think im close to what i want ,just got a small thumpy clunk when on full brake pulling into my drive way ,, and on a full lean it feels a bit like it could be smoother a little less harsh and on the rails if that makes sense ,,
Rebound thump would not be caused by too much oil. Too much oil will cause the bike to feel like it's bottoming out on compression. You say it happens on braking pulling into your driveway. That sounds like compression, not rebound and could be caused by too much oil. It's hard to diagnose via descriptions. The correct fork oil amount is not determined by volume but by the oil level. On the conventional forks used on VRSCA/B/D/DX/X models this is measured from the top of the fork tube to the top of the oil with the springs and spacers removed and the forks fully compressed.if ive got the right oil amount is there any way i should get a rebound thump or bottom out ,with stock springs.. say like when i said i get it under full brake pulling into my driveway
or could it be possible im getting mixed up and its the dreaded front end clunk
A bit more oil then spec, 20-30cc will firm up the spring action. This is done quite often to tune a system. There eventually comes a point where you cannot bottom the fork to full travel as it will hydro lock. This can force the seals out. What that point is on your bike, don't know. The extra 50 cc might not be critical in function range. If you have full travel to the bump stop, by whatever means you test this all you've done is increased the spring rate by reducing the air chamber compressibility zone, so no issue.Hi. I've recently did new fork seals on my zx12r 2001 model and as per manual I stating 450ml to be used per for so I put in 500ml per fork. Will this extra 50ml create a problem when I ride the bike. Kindly advise please.
Thank you Ron. Much appreciated brotherA bit more oil then spec, 20-30cc will firm up the spring action. This is done quite often to tune a system. There eventually comes a point where you cannot bottom the fork to full travel as it will hydro lock. This can force the seals out. What that point is on your bike, don't know. The extra 50 cc might not be critical in function range. If you have full travel to the bump stop, by whatever means you test this all you've done is increased the spring rate by reducing the air chamber compressibility zone, so no issue.
Steel slider shrinks actually. No two seals fit exactly the same. That and there's a very slight variation in tube dia. Could be this one has a hair lighter seal lip contact. As you say, clean it but you would need to pull the chrome cover and wiper to really clean or residue between the seal and wipe will smear for a while. It's also possible there might be some crud on the seal lip. Look into seal mate to wipe the lip, while you have the wiper pulled down and out of the way. Boy, that deal must think they are something special with that hour rate and times. While I have all the equipment to work on these, Woodstock is hardly close to the GTA. These are about the most simple of all inverted forks.frogman......unfortunately, the garage is not heated. I never would have thought about shrinking seals because this is the first time seeing an oil stain on the floor.
My bike's been problem free since I got it in 2015 so expected to eventually have issues.
Going to give the fork(s) a good cleaning and monitor it for now......
