On my 10K check, I had the rear tire changed due to picking up a roofers tack. The tire still had another 2-3,000 miles left on it. Still running the same front at almost 12K, but it is getting there pretty quick. I will need to change it out soon, as I am wondering about grip in turns with rain.
Since I do not do burnouts or any racing, the tire life would be longer.
The valve shim adjustments have me wondering if the dealers are really opening up the covers on the v-rods when they do their inspections. From what th emanual says, you have to lower the engine to do both F & R. When I picked mine up from the dealer, no adjustments were necessary per the tech.
Might they start the bike up, let it get to operating rtemp range and listen with earphones for noise? No noise.. no adjust? Sounds crazy I know, but between Porche and HD might there be something here that MoCo ain't sharing, like if no adjustment needed at the 10 or 20K, should be good for 50K thereafter?
Since this was a Porche design, what is the recommended lash/shim check periods for their motors? I can't imagine that a Porche ownere has this done every 10K, as that would seem to be out of the norm, way too much service.
IDK, I am not a Porche owner, but it does seem unreasonable.
