1 - 12 of 12 Posts
I know there were a couple of post about the Ricks tank being close to the tire when fully extended. Today while doing an oil change I took both shocks loose so the suspension could travel it's full sweep, I figured I would snap a picture of mine. Now I have a cfr swing arm but it is stock length exactly and use a standard 72 tooth rear pulley, 30 tooth front and 150 tooth belt. I had mentioned before that my bike looked like a dirt bike before the tank would contact the tire and doesn't come within one inch while the shocks are installed so the only way this could ever happen is both shocks to break off and go over a very high hump in the road to completely unload the suspension.
Dirt bike v-rod
Chrome is king!!!
Max said:
I know there were a couple of post about the Ricks tank being close to the tire when fully extended. Today while doing an oil change I took both shocks loose so the suspension could travel it's full sweep, I figured I would snap a picture of mine. Now I have a cfr swing arm but it is stock length exactly and use a standard 72 tooth rear pulley, 30 tooth front and 150 tooth belt. I had mentioned before that my bike looked like a dirt bike before the tank would contact the tire and doesn't come within one inch while the shocks are installed so the only way this could ever happen is both shocks to break off and go over a very high hump in the road to completely unload the suspension. Dirt bike v-rod
Yes, but if both shocks broke off then technically there wouldn't be any suspension left to unload. :D
Jim J said:
Max, off the topic, but did you switch back to the anodized skins?
I have my airbox being repainted because of a snaffoo. So right now I am anodized again.
Resident Tugboat Cpt
Snafu? What gives Max?:stilpoke:
LOL I didn't join the drop club if thats what your asking. I had a blemish that showed up as the paint cured and while very small the painter insisted on repainting it.
Chrome is king!!!
You sure it wasn't the MOCO getting on your back for using a picture of an eagle? We all know they own the rights to anything with an eagle in it. LOL
Oh ok, just checking.
1130cc Mike
But Max! I thought all kindergarden fingerpainters were off today.
1 - 12 of 12 Posts
