DYNABEADSI have chrome CVO rims. I static balance my own tires, but I have trouble getting the weights to stick in place for very long. Any suggestions??
Yeah, there are some ignorant shops out there.....or those with their own motives for doing the old way.The guys that fit my tyres refuse to stock dynabeads.They don't believe the science behind them.They much rather you come back in when a weight gets launched into the roadside scrapyard for toxic metals and cough up another balancing charge.
They are easy to blow into a mounted deflated tyre with a tube and plastic bottle and mine are on their third go no need to replace each time.
I think that the beads have not really gone mainstream due to; cost, perceived hassle of inserting and removal.I have used balancing compounds with success. I have read quite a bit how they are supposed to work.
Without entering into a debate as I have no real scientific knowledge of the subject, would love to know why this product gets zero support from any OE car, bike, or tire manufacturer. Now that I have proper balancing equipment I don't use this stuff anymore, but I'm still interested.
I use Ride-On in all my vehicles.I have used balancing compounds with success. I have read quite a bit how they are supposed to work.
Nothing against dynabeads and have used them in the past. I now have a balance unit, plus my tire guy hates the beads rolling around his floor, should he miss a few when he vacuums them out. As for stick on weights there are two basic types. One uses a more papery adhesive strip, the other a rubbery foam type similar too what 3m tapes used to hold car moldings on. That's the one you want because it's water proof. Good cleaning of the area on the chrome and they are there for the life of the tire.I have chrome CVO rims. I static balance my own tires, but I have trouble getting the weights to stick in place for very long. Any suggestions??
That looks great, I would use that Ride On if I can find it in the UK ...I use Ride-On in all my vehicles.
It not only protects you from most punctures but eliminates wheel weights (unless the wheel/tire combo are several ounces out-of-balance). The dealer I bought my bike from used to install it in every bike they sold. There's likely some liability concerns that hinder endorsement by major manufacturers but there are plenty of individual testimonials available on their website.
There's a UK Ride-ON site but for some reason it's undergoing maintenance now. You can also contact the company and ask for UK dealer info.That looks great, I would use that Ride On if I can find it in the UK ...
Ride-On is a water based colloidal suspension with no chemically active components except for corrosion inhibitors. It washes off with water. If BST wheels can handle inflation with air (unless specially processed this will have some water vapor), then Ride-On won't cause any issues. Also, when properly installed, it only touches the tire, not the wheel.To clarify. I used ride-on with tubes doing adventure riding. Many thousands of miles of agressive riding in remote Australia and never had a flat. I don't see it being worth the mess on tubeless, and would never trust any chemical inside my wheel with BSTs.
I hand balance jet wheels that land at up to 168 Knots ( 220 Mph rated tires ) we use weights that go under the wheel tie bolts, different offsets, weights and locations. Never any crap in inside the tires, other than the tire makers installed weight patches, no chance of weights flying off.
Not really. Takes a while but far enough out of balance they shake the shit out of the landing gear, just after leaving the ground when they are free wheeling. On one of my small planes back when I had one tire way out. Normally they don't balance these little tires but this one, on every take off, I applied brake to stop the bitch from shaking. I balanced it and all good.First landing wouldn't the balance be that far out to make it a worthless effort what with all the smoke and screeching.I've seen hostesses jiggle uncontrollably and always thought oh yeah another Dunlop trashed should run beads.
It's not a liquid, it's a colloidal gel. Once it coats the inner tire tread patch area it pretty much stays put. I have no experience with it in a racing application, but I can't imagine why it would be a problem....If Ride On stays " wet " and you lay the bike down it could get around the bead area and reduce friction, hopefully their different formulas take that into consideration. Inside a tube like Mike says I would feel better - tubeless I need more testing data to make an informed decision. The Dyna beads being dry, and not a sealant not a problem. My 2 cents.
