Tickling noise issue... i think this isn’t normal sound.
I have tried 3 differend pipes (2 different stock headpipes with 2 different and akrapovic), changed exhaust gasgets, valve check and cams chanced stage 2 cams, but still this tickling...
In this video, stage 2 cams, akrapovic exhaust, semi topless (drilled holes on airbox, but top airbox cover still on.
Can it still be exhaust leak? When i tried hear where sound comes (with garden house) front butterfly valve sounds little tickling, but not that loud what heard on video
Tie One On
get a length of tubing hold one end to ear other end move aroung the bike looking for location
Way out in left field here but I had same problem. Turns out the clasp on the very front of the airbox was loose. it's a small piece about 1.5 inch in length holding top of box to bottom of box. Just remove it completely. It's not needed.
Not too sure about your problem, but when I inspected my bike w/ the stock heat shields on the header pipes, a couple bolts on them were loose. This made a very small, metallic noise that was fixed by tightening them up.
