1 - 7 of 7 Posts
My throttle % is jumping from 2% to 3% it just started today and i am leaving for street vibrations tomarow how do adjust it ? is it a quick fix
MY idle is all over the place
Dilligaf
Welcome! I don't think it will be an issue unless it gets around a 5% flux.
Dilligaf
It would also help if you tell us the year and type of bike, mileage, whether your running a fuel management device and how you are getting the readings etc.
i just tryed playing with the power commander and the idle is more stable now but at 0% now and now after start up the engine light comes on then goes out
07 night rod special with a power commander and tab cans and a high flow air filter
i just want it to idle smoth it was jumping 500 rpm
Friend of Max.
At idle i set the pc to 4000 and 2% at idle but the engine light is on so i am goint to check the code. the bike is idleing ok
1 - 7 of 7 Posts
