On my 06 with 4500 miles This problem has just started recently. When you let go of the accerator grip the engine does not completly go to idle. It seems that the linkage is not closing back up all the way. You can return it manually by twisting the grip and having the cables pull everything closed but otherwise stays just slightly open.This only happens when everything is hot. I have had checked the cables, linkage when cold and everything is fine. I cleaned the linkage and springs and sprayed a little silicone spray to try to fix this problem but hasnt fixed it so far Any Ideas. The bike is completly stock
