1 - 3 of 3 Posts
Did you reuse the stock lower washer? I used the washer/spacers supplied with the progressive shocks but wondering if I really need that larger spacer on the lower rear.
Bob
The 440 shocks are wider. You need the extra. If you don't use them it will not be plumb.
I used the supplied washer/spacers and all lines up. I just did not put
the flat large washer on the outside (the flat washer that is larger than a quarter from the OEM shocks).
Bob
1 - 3 of 3 Posts
