41 - 60 of 874 Posts
Departed the Fix.
Discussion Starter #41
hey Fly , just want to double check iF that Tiger belt guard Fits the muscle ..... ?????
Have you Fitted yours yet , just confusion wether or not F same as other Vrods For mounting belt guards ( confusion over Rizoma one )
Guys-- I didn't get to this today; between a doctor's appointment, a brake job, karting and a Big Frelling Margarita, the day ended before I could get serious about the bike.
Wife gave me a pass to play in the garage tomorrow, so I'll get to it then.
Cheers--
R.
all good bro !!! as Lastinline pointed out the Harley catalogue says the chrome belt guard Fits all VRSC except the R , so i sure it will Fit ...
Departed the Fix.
Discussion Starter #43
I didn't pull the stock belt guard or pulley cover today, but comparing the two, I'm about 99.99% sure that they'll work. Sure enough that I sent the belt guards out for powdercoating today.
R.
Departed the Fix.
Discussion Starter #45
A few side pics of the exhaust tips downturned. This is a temp fix until I get the TAB slipon's installed. Looks far better than having the tips angled to the side imho.
R.
Departed the Fix.
Discussion Starter #46
Locking gas cap: Stant 10501. It's a little wider and a little taller but seems to clear just fine. Hopefully, it will work as well with the Bitchin' seat.
On my R I had a locking Corbin seat that I got used to unlocking when I refueled. This is simply for peace of mind-- it's not that I think somone will steal my gas (although at $5+ a gallon.....), but it's to prevent some mouth breather from screwing with my bike when jealousy rears it's ugly head. $13 is cheap insurance to prevent said nipplehead from ruining my day by pouring his beer (or whatever) in the tank.
R.
Departed the Fix.
Discussion Starter #47
Budman's riser: 0.75" rise, 2.0" pullback. NO change in cables required. Budman's instructions tell you to loosen the clutch/brake cable at the reservoir and pivot them to make enough cable to move the bars to full lock, but I found that wasn't necesessary. Instead, I removed the left side grill cover and rerouted the wiring OVER the brake and clutch line. by popping the wire quick disconnects, I was able to thread the wires on top of the stainless lines-- it gave me just enough slack that I didn't have to loosen anything up at the reservoirs.
As far as the riser itself goes? Fit and finish are FANTASTIC-- and it feels unbelievably better in comparison to the clamshell riding position. I have a fused spine, so I really REALLY needed some relief. This did it-- it was a different bike from the moment I started to ride. The pictures really don't do it justice-- it looks great in person and appears essentially stock on the bike-- you wouldn't know it wasn't supposed to be there if you didn't know any better.
I'm going to install a '12 DX shield to make the front flow a bit better, but I kindofsortof forgot to order the longer bolts that are required for mounting so that project's on hold for a few days. Whoops.
It's worth noting that I tried Hanny's riser (which is for sale in the Classifieds section). Nice product, but you get all up, no back-- which wasn't working for my specific case. Honestly? If you're feeling stretched forward on the bike at all, do not walk but RUN to your computer and PM Budman.
It's that good.
R.
Departed the Fix.
Discussion Starter #48
Pivot bolt covers: I've always felt that these should come stock on the bike. I got unbelievably lucky and managed to source the last set of Superchicken's swingarm covers on the planet. The quality is top notch, and HD wishes they could make parts like this.
My deepest thanks to Superchicken!
R.
Good Muthafarka
R.
No engraving on them ?
Departed the Fix.
Discussion Starter #50
I thought about it but didn't for several reasons.
1: The covers are just press-fit with an o-ring and can rotate fairly easily. Keeping the engraving horizontal would have driven me to distraction.
2. They're very close to the derby and pulley covers which are busy enough with writing.
3. I have Bicep's VRSCF fork leg badges. The bike would have gotten too crowded.
4. I can always change my mind later.
5. They match my unengraved front and rear bolt covers.
R.
Good Muthafarka
R.
Fair nuff !
Departed the Fix.
Discussion Starter #52
Important safety tip of the day:
If you're going to relocate your passenger footpegs and use AW brackets to do so, here's something to consider:
Said brackets have a small metal tab on the inside where the pivot point is. The stock pegs have a groove in them that matches said tab so when you fold the pegs back, they seat flush.
Aftermarket pegs (at least RSD and Joker Machine) don't have this groove, so if you don't do anything the pegs won't sit flush when folded.
You'd think the obvious solution would be to dremel off the tab. You'd be right except for one thing. THE BIKE IS NOT REPEAT NOT SYMMETRICAL. I knew this, but didn't factor it in when I fired up the dremel. The left shock mount is actually extended out to make clearance for the belt and drive. Which means that if you dremel the tabs on the bracket's symmetrically you've just screwed yourself.
THAT was a $120 mistake.
On a completely unrealted note, anyone interested in some AW brackets with the tabs dremeled off?
Sigh.
Learn from my mistakes, Grasshopper.
And the REALLY irritating thing? I realized what and why about two milliseconds after I fitted the left passenger peg. Whoops.
R.
ha ha .... the dremmel jokes never get old !!!
Hey like the tips turned down and man LOVE the pivot covers !!!
by the way , did Bicep ever do pivot covers ???
FFFWD
R.
I did this for a time before I got my Bassani's. I like the look. However, I soon found out that they would scrape this way before my footpegs would touch down so I turned 'em back out to save what was left. Just sayin'... Caveat emptor! If you ride anything like I do they will scrape first!
Sent from my Motorcycle iPhone app
Departed the Fix.
Discussion Starter #58
When I went out riding with a few of my buddys last week, they said that it looked like I was almost dragging them-- I thought they were nuts since I figured the peg squealers would go firest.
Whoops. Might want to reconsider this.
Besides-- it looks like my M3 is about to be sold, which will help accelerate the modification plan.
R.
oh man sure there enough in budget now For some Forced induction !!!
Departed the Fix.
Discussion Starter #60
Been there, done that. I put a blower on a race-prepped Solara a while back and ended up having to work directly with TRD and their race team to design a one-off small-diameter pulley and then a serpentine belt tension system because the smaller pulley caused belt slip.
Living at 6000'? It's not worth it. Too hard to get the compression up enough to make meaningul power (at least on a supercharger). Not enough bang for the buck, and then once you do get things working at altitude, you're well and truly screwed if you go down to sea level.
Floor it anywhere other than Denver? Kaboom.
Nope, I'm happy with incremental changes.
(although I will admit that I'm going to miss the M3-- that car was FUN in the twisties. I left the motor mostly alone, but it had a suspension that would let you corner at insane speeds without losing adhesion).
R.
