1 - 2 of 2 Posts
Bike is stock except for drilled exhaust.
Settings: 3.5, 7, 3, 7 (TFI's recommended settings for stock bike with no download)
Results: Better throttle response in first gear, no surging. On a full-throttle roll-on from 40 and 50 mph there seems to be a slight hesitation. Other than that it accelerates well.
I have the box sitting on top of the battery. The box can be pulled out to make adjustments by removing the left side cover.
Easy install.
drag racer
seems like i had my main jet setting on 3;30 . i sell these which is the 3rd generation of the tfi http://www.electronicjetkit.com/default.asp you can adust this unit while the bike is running and in motion. it may not be very safe adjusting while in motion so i don't recommend it.
1 - 2 of 2 Posts
