Wouldn't really matter 1130 or 1250 but no engine would last 500 at max rpm. I'm sure they chose a good mid rpm for that. What that is, I'm not sure we will ever know.we know that the 1130 engine past the Düsseldorf Test but did the 1250?
only the 1130 is in the porsche museum.
also the test is done on a dyno for 500 hours is it at redline for the full 500 hours?
It's a durable engine,proven by us lot in the real world.Dusseldorf test is a computer simulation of on road engine loads produced while racing flat stick from forget where :banghead: to you guessed it Dusseldorf.If you want to split hairs over bore size you should also debate what oil they used to hold the engine together before,during and after the hand grenading would be more relevant.In other words is the test null and void if HD recommend a different oil to that used in the test.we know that the 1130 engine past the Düsseldorf Test but did the 1250?
