Well thanks for the advice guys. I was able to take off the rear fender and get the light assembly out. For any one who may have this trouble in the future here are a few tips.
Use good amount of force with a good size screwdriver and make sure you pull up the rear of the light from above with some force. This latch needs more force to push in than I thought it would. If you have trouble just takes the fender off. To take off the fender, first take off the seat and you will see the four nuts that hold it to the body. Good luck.
...and don't forget to put some grease on the latch before reassambly. Makes it a lot easier the next time!
Will Work For Mod $$
It's easy if you have 2 people doing it. One pushing with the scewdriver and the other pulling the light up from the rear. It does work, did it this past Sunday.
