1 - 20 of 24 Posts
$70 shipped?
Discussion Starter · #12 ·
Fuler is loaded with 9 maps which are tuned to TAB pipes. However, it does have 3 pots which you can used to tweak to fine tune to your setup.
drag racer
it'll work on a 08 but you'll need to get the diodes to plug into the harness side of the ecm for the O2 sensors. The XiED (13.8) will richen the closed loop fuel by about 8%, the X14iED (14.0) by about 6%. i've never used the x14ied or xied but i've only heard good reviews. it just depends on what your looking for.if you want something to set and forget about it then this is a good option, if your one that feels you have to tune on the bike every time you ride it i'd recommend something more advanced.
if it doesn't have O2 sensors its plug and play, i would adjust it back to a stage 1 setting and go from there.
drag racer
it looks as if it doesn't have the O2 connectors on the harness
Is this supposed to plug into the O2 sensors?
drag racer
no, it plugs into the fuel injectors. some of the newer bikes that have O2 sensors will need the "kit" to bypass the O2 sensors. i think the xied or x14ied will work fine with this unit.
1 - 20 of 24 Posts
