I just installed the TAB pipes with the fueler,it sounds great. I'm wondering about the stock exhaust bracket that runs to the rear (the long rod). I left all of it on so I could keep the exhaust bolt up under the middle of the frame. Is there a small bolt on plate u can use so this can be taken off? If this is taken off I don't think there will be enough support for the pipes. What did you guys with the tab exhaust do? Any suggestions? Thanks
