I believe you can simply eliminate the system by removing all parts and installing a set of standard brake lines from the masters to their respective calipers. You can get all parts needed to fabricate custom brake lines at Summit.
Wouldn't want a HD ABS system on my bike!!Would love to add abs brakes, but was told not feasible.
No doubt it's not the best system regarding the small bearing encoder but at least once it's kept me upright and stopped. I also do the 2 year flushes and cycle the ABS module while doing the fluid swap.Wouldn't want a HD ABS system on my bike!!aper:
Appreciate what you are saying Ron but for me any ABS system that is designed to default to no brakes on failure, which appears to be the case from my readings here, doesn't do it for me.No doubt it's not the best system regarding the small bearing encoder but at least once it's kept me upright and stopped. I also do the 2 year flushes and cycle the ABS module while doing the fluid swap.
Well yes, there is that pesky little problem too. Even though only one will fail, that can be bad enough if you need them. I guess the NHTSA doesn't care much about that fact either or they would have bitch slapped HD by now. HD got off easy with that stupid fluid flush recall, rather then having them replace units that were prone to corrosion. I suspect the HCU in later years, beyond the recall dates have plated valving to counter this and likely a different supplier and part numbers.Appreciate what you are saying Ron but for me any ABS system that is designed to default to no brakes on failure, which appears to be the case from my readings here, doesn't do it for me.
For sure!!Well yes, there is that pesky little problem too. Even though only one will fail, that can be bad enough if you need them. I guess the NHTSA doesn't care much about that fact either or they would have bitch slapped HD by now. HD got off easy with that stupid fluid flush recall, rather then having them replace units that were prone to corrosion. I suspect the HCU in later years, beyond the recall dates have plated valving to counter this and likely a different supplier and part numbers.Appreciate what you are saying Ron but for me any ABS system that is designed to default to no brakes on failure, which appears to be the case from my readings here, doesn't do it for me.
One of them being the patent office. Don't ask me how I know.For sure!!
I reckon HD with all their misgivings must have some very influential friends in important places.
I`m not sure I understand this . If your ABS module fails you have no brakes ? I would have though just your ABS stops working . The brakes work like normal just no ABS function .Appreciate what you are saying Ron but for me any ABS system that is designed to default to no brakes on failure, which appears to be the case from my readings here, doesn't do it for me.
That's how a correct ABS system should work ( like everybody elses) but HD prefer a system that defaults to fail. Exactly as you say, when it fails you have no brakes on that half of the circuit. (front or rear)I`m not sure I understand this . If your ABS module fails you have no brakes ? I would have though just your ABS stops working . The brakes work like normal just no ABS function .
That's how it should work but HD used aI`m not sure I understand this . If your ABS module fails you have no brakes ? I would have though just your ABS stops working . The brakes work like normal just no ABS function .
Thanks for the information . I can`t believe this was allowed to be put into production . I also can`t believe the government has not had a recall .That's how it should work but HD used aaper: system where it wouldn't do that. The HCU has dual valving for front and rear operation so if one valve sticks fluid will not travel to the brake it supplies because the orfice is blocked. This shows up as a rock hard lever or peddle and no brake function. Either front or rear can fail but both would be rare. It really is a stupid system and should have been outlawed as soon as the flaw was discovered. It seems NHTSA don't have balls when it comes to HD. On any car or truck, that would be slapped down so fast it would make your head spin.
In fact, you do not even need to change the brake lines, if you install a nipple to join the cables will solve the problem more quickly. You can leave the entire electronic system connected so that it will not acknowledge any error code, since it will understand that the bike is not being braked and will not trigger the system. View attachment 529697te=Kevin.choe1983;4724795]Bike: 2009 VROD-NightRod
I know many have switched from ABS to Non-ABS brake system for multiple reason. I'm heavily considering doing the same due to HCU failure and the dealership estimates $700.
Could someone provide list of parts they've used and guidance on the procedure?
Thanks in advance
I bought TwinScan2 ABS to cycle the HCU.So Ron are you going to tell us how you activate the ABS when you flush the system?
I flushed brakes after I got my bike even though it only had 6 miles on it but it had sat around unused for two years. The brake fluid was bad and the clutch fluid was horrible.
