Taking the bolt off from the other side might help to remove the shaft..
Taking the bolt off from the other side might help to remove the shaft..Hi guys,
I have a Vrod NRS 09, and im trying to disassemble the engine from the frame but the swingharm is stuck to the engine block.
I've tried the basic things, like brute force, wd 40, and a penetrating spray ( once a day for 7 days) but is still stuck.
Anyone has any useful tips for me to use?
ALSO, once you DO get the shaft out make sure to slather it with some nice copper anti-seize. I buy this in the large jar for all my rust buckets: https://www.grainger.com/product/3C...yAGUv_6gBN9pxXE99tkaAoT0EALw_wcB&gclsrc=aw.dsThank you all for your responses, I will try all the suggestions.
@hedgehanter In fact, when I try to turn with a hex key, the whole engine block lifts up, even with someone holding onto the block."
@mukle than you for noticing, when the bike is being worked on it has a support below the engine.
@Knut J @freudie1 I will try those options and i'll buy some Kroil as well ahah
Did you manage to take it out?Thank you all for your responses, I will try all the suggestions.
HiDid you manage to take it out?
Thank you Mukle, indeed I have this bike since 2015 and I always use pressure wash, in summer it's normal to wash it once a week because I ride every day. You think it might be the cause of the problem?Great idea. Hope that it will loosen soon. Have you used pressure wash when cleaning the bike? I know this is stupid question afterwards but these are quite typical symptoms among wheel and steering bearing problems.
I advise you to give your Motorcycle for repair, I think they will definitely help you there)Hi guys,
