View attachment 612759 View attachment 612758 07 vrscdx is this everything I will need to redo the swing arm got some good help
Pivot says used which means it has wear in the bore. Get a new one. Might as well change the front motor mount cushion while at it. All of the stock mount parts are fine. I'm not sure on the Poly vrs rubber thing. I've not had good luck with Poly bushings before. My case aircraft engine mount bushings. They sagged bad from heat. Went back to old school rubbers.
It says use but it is still in the bag
