Ok, so I have the workshop manual but im wondering if I can remove the swingarm without completely stripping the rear end e.g. remove wheel, shocks etc.
I just want to check and lube the swingarm pivot.
Could I just support the motor with a jack/stand, and lift enough to extend so wheel is on the ground with shocks extended, then pull the shaft out ? ...or will the tension from the shocks still prevent this ?
thanks
thanks
