1 - 9 of 9 Posts
Maybe someone has some information for me.
While I had my bike up on the jack this weekend for wheel cleaning I bumped the rear wheel and heard a clunk. I haven't pin pointed where it comes from but I can hear it if I grab the rear wheel while faceing the license plate and move it side to side. I do get some side to side movement. I have not measured it yet but it looks like it may be around 1/8".
My questions are:
1. Is this normal?
2. Could this cause my problem of pulling to the right?
3. Has anyone else noticed this?
4. What, if anything, needs to be done.
Thanks,
Paul
SNAFU
1. Is this normal?
NO
As well as instability in the corners, wandering all over the highway and various other handling related quirks
First I've heard of
Get the bike to the dealer and insist they check the swingarm bearings. It sounds like one or both of them are bad or at least the swingarm bolt isn't tight.
Next time we get our bikes up on the multitude of lifts we all seem to have purchased in the last few months, lets check and report!
Mine is on the lift as we speak and the rear wheel is as solid as can be. NO movement at all.
Is it the wheel moving in the swaingarm or the swingarm moving in the frame. Maybe this is another case of bad wheel bearings. Did you ever have grease streaks on your wheels starting from the center?
Ken
Ken,
I think the slop is in the swing arm pivot. The bike only has 2000 miles on it, so it shouldn't be the wheel bearings. I have never seen any grease on the wheel. I am going to take it in for inspection.
Hi All
My dealer just replaced my swing arm bolt. HD has a new bolt for the swing arm with a few more threads cut onto them. This allows for more pressure on the swing arm bearings. I was having an engine vibration and they felt this may be the problem. I don't have the part number for the new bolt, maybe Max has more information.
1 - 9 of 9 Posts
