In the process of installing 5 Gallon trick tank...while I am at it getting some new rubber on both tires also and new brake pads.
Going to also replace front and rear wheel bearing sets while the wheels are off....hd 9247 bearings are approx 30 bucks each...ridicously priced IMHO.Any opinions or anyone ever use all balls bearings? can get them for 12 bucks each seem to be made by KML.Also looking at the swing arm bearings,did not notice any play in the swing arm upon disassembly,but I did not check it either....I notice the swing arm bearings do not spin at all when I try to move them with my finger should they spin freely or is this normal the bike is a 2003 with only 7K miles on it.Any insight is appreciated thanks.
