Does anyone have knowledge of the Super Brace or similar product that helps V-Rods on the highway or cornering? Is it worth the $175?
I think the HD ones used to be $40-$50 more than the superbrace and that's why people where buying them but now it sounds line they are about the same price.I have the Screaming Eagle brace and love it, You can feel a difference. the front end seems more stabil.
New Sportster 48s come with braces from the moco so they are obviously functional items.
Did you change the springs with those Ricors? or just add the Ricors and change the oil?The biggest thing I noticed with mine was the front wheel immediately stopped tracking the cracks in the roadway. I felt a larger difference putting my Ricors in my forks and if I had to do it all over again I would do both items probably before I did my exhaust... yes the combination of the two made that big of difference.
I kept the stock springs and used 10w oil.Did you change the springs with those Ricors? or just add the Ricors and change the oil?
THIS is a proper fork brace, NOT the Superbrace or the similar brace from Telefix. There are two problems with a Superbrace is where it attaches to the fork. The top of the fork tube around the fork seals is the weakest, thinnest part of the fork. It is least able to bear the loads of a fork brace. Number two, such braces do not have sufficient clamping area to do the job. You would need a clamp that grips 50-75 mm (2-3 inches) of the fork stanchion to be effective. Because they attach to the weakest part of the fork, if you tighten them down fully, you will distort the fork seal. If you do not tighten it fully, it is doing little or nothing.Sportster 48 stock:
