I'm on my '10 DX the other day and as I duck out to pass a cage, the bike jerked and died for a split second in mid-pass. Scared the snot outta me and about jerked me outta the saddle. I completed my ride and it did it two or three more times. I got it back in the barn and cracked open the books.
It felt like a drinking problem, so I started there. I discovered I was about 15k overdue for a change on the pressure side fuel filter (I know, I know...but when the task isn't in the service schedule and you ride all the time, it got overlooked) so I swapped that out. Bike seemed to run better at cruising speed, but it still had the herky-jerks. Yesterday, I cleaned the four main ground points, checked and cleaned the plugs (which only have about 8k on them), checked the battery (good health and charge), and cleaned and tightened the battery cables.
I also swapped the fan relay with the system relay, since that was an easy task. Odd thing is, the fan immediately kicked on with the ignition switch in the OFF position and continued to run for about 30 seconds until I cycled the switch. I found that dubious.
So now I hafta road test it again and see what's up. Any thoughts or advice until I can report back?
Sent from my SM-T560NU using Tapatalk
