Hi guys,
A couple of days ago, I noticed that only the top radiator fan was spinning while I was stopped at a red light. I know both fans are supposed to run at the same time so something was not right. I did some tests this weekend to troubleshoot the issue. The first test I did was to pull the main fuse and wait a while before putting it back on. When I put the main fuse back on, both fans started spinning. In the second test, I swapped the electrical connectors for the two fans and let the bike warm up to operating temperature. Only the top fan started spinning again when the coolant got hot enough and the bottom one remained idle.
The bottom fan rotates freely by the way when I push it with my fingers while the bike is off. I also checked the error codes and I am not getting any. Any ideas about what might be going on here? Is there anything else I can try?
