O-FNG
I heard about a company that modifies the stock rear rim to go from 5.5" to 6.5". Does anybody have any information on this process, such as who does it, contact info, etc.?...thanks, John.
SNAFU
It's not going to buy you anything, the 180 and 200's (the biggest your going to fit on a 6.5) are made to fit the 5.5 rim. You'll screw up the handling if you extend the bead 1" on these tires and the 240's won't fit either.
O-FNG
I was wanting to go with an Avon 210/18. The tire is made for a 6.25" rim, but will work with a rim in the range of 6.0" to 6.5". Avon said people have put the tire on the V-rod stock rim, and have the same thoughts as you about changing the handling of the bike.
SNAFU
Ah, I forgot about the Avon 210. ;) Since you're in FL, where the most turning we get to do is on off ramps, I think the handling issues shouldn't be that bad. It's the stock fender I'd worry about. The 210 might be a real tight fit.
O-FNG
I have already hacked up the inner fender, so a little more cuttng and grinding won't be an issue. The only place I heard about making the stock rim wider was a post on another forum about a company in Germany. Looking for somebody a little closer to home.
miscellaneous debris
contact RMD billet I spoke with them a while back about widening the stock rim they said they would work on it but I have not heard back from them....7.75" is the whith that speedpoint makes for a 240 with stock swing arm http://www.speed-point.com/english/news/frei.html
I also contacted a rep from avon and he said that they make no shuch tire 210????
spit happens
If traction is what you are after then look at the Avon AM23.They make a 200/55 X18.
O-FNG
Just looking to go a little bigger than a 200, but not invest a fortune to go with a 240 (plus I want to keep the look of the stock wheels). Hence, the idea to modify the stock rim, and go with the 210.
