1 - 3 of 3 Posts
I am looking for instruction (help) as to installing the "T" Harness to the proper recepticle on my v-rod. Where do you tap into the existing electrical?
I am using a Cycle Sounds Sytem and the "T" Harness supplied needs to connect someplace whereby everything remains under warrenty with Harley etc.
Where can I locate the electrical connector that accomodates the "T" Harness?
Anyone with any experiance on the subject...your input would be appreciated.
Has anyone had any experience with the Cycle Sounds Model #4405-0005? I am looking to install 150 watts of power , and I am also looking for suggestions as to where to mount the mini amp.
Thanks in advance for your remarks,:notworth:
Not sure what a "T" harness is but in order to hook into the bike's accessory circuit, use the Orange wire with White stripe.
Btw, Welcome to 1130cc. :vrodforu:
I installed a similar kit from Pyle last year on my VRSCA. The included wiring harness is for the rest of the HD world. VRods are the exception. Use the Orange/White wire as indicated by Rickg61 as your lead (positive) with an inline fuse and frame ground. Places to mount the amp are scarce. After staring at the bike for hours I finally mounted mine below the gauge housing, looks good.
1 - 3 of 3 Posts
