Hi All,
So as one of my winter jobs I decided to re grease the bearings in the headstock. Top one looks great but the bottom one is screwed, red rusty. Taper bearing came off the shaft no problem, but getting the race out of the headstock is horrendous. No access to the lip to hit with a cold chisel, bought a proper puller but there is minimal lip for it to gra
Have heard that if you use a tig and run it around the outer race, when it cools down the race shrinks and drops out.
Question, is it ok to use this method or will it fry some of the elecrtonics ?
Obviously I will disconnect both leads from the battery, and pull the main fuse. Anything else I should do, disconnect the ECU maybe ?
Any advise appreciated.
Regards, Jeff
Regards, Jeff
